Hello, guys,
I have a water cooling system with large radiator, DDC 3.2 PWM Elite, ASUS C6H monoblock and an Aquatube as reservoir.
Unfortunately there are several air bubbles in the monobloc and I just can't get them out.
Do you have any tips?
Regards Stephan
After the pump it goes directly into the monoblock, then further through the radiator (above the case)to the resrvoir (before the radiator in the upper right) from the reservoir back to the pump.
Regards Stephan
