1 - 20 of 36 Posts
I dont think there is but I still use my 100 psi compressor fill it to like 50 or less and I blast away.
After 2 years now nothing has been damaged.
I've done it on a variety of motherboard OEM and Enthusiast.
· Premium Member
I just take my tower out to the garage and blow it out with a big compressor, I'm sure any one would due.
Discussion Starter · #8 ·
Dude I just use my large shop compressor and the appropriate attachment, blows all the dust to the next dimension. Just make sure to test the air on yourself first, make sure it isn't moist.
As I live in a pretty dry area, moist isn't a problem. If some creates inside the compressor's tank, just discharge it from the bottom valve a couple of times and let it refill.
I have cleaned my pc with an air compressor since years, even blasting at 120 psi (8atm), never had a problem, dust went off perfectly.
+1 for air compressers I hate stupid a55 cans of compressed air , if you dont do it right it can blow water. My friend has used his air compresser for yrs ! ( no problems) I take my rigs over to clean em when i can!
Ps i just bought a stupid can the other day for $7 and got it home ( no straw ) arggggggggg
1 - 20 of 36 Posts
