1. Correct
2. Correct
3. Correct
Though if you notice, your front panel has a 200mm fan so, it will likely fit the drive bays (well zip tying it outside of the bay basically) but you wouldn't get higher benefits plus it will look bad.
2. Correct
3. Correct
