Originally Posted by sotorious ![]() Also if someone has an H50 with about at about 28c room temp and that is oc'd |
Originally Posted by Hadenman ![]() You keep it 82 °F in your room in Houston? Yuck. That's gotta be pretty rough with the humidity the way it usually is there. I have my i7 OC'd to 3.8Ghz and in my room, which is usually around 21-22 °C, the core temps range from 35-40 °C at idle. This is with a push/pull setup on my H50 using these Aerocool fans. If I open my case up, those temps drop by about 3-4 °C. Running Prime95 blended for an hour, the core temps max out in the 76-78 °C range. I recently got my hands on a VenX, and I'm tempted to run some comparison tests. I've already captured a lot of data on my H50 performance using the RealTemp plugin for RivaTuner. But, I'm a noob and I didn't leave the backing on the double sided foam tape. So, I gotta consider if I want to deal with peeling it off using the hair dryer & dental floss method. |
Originally Posted by Fons ![]() Its 57F here in Michigan and that's pretty warm. I would hate to be in 80 degree weather right now... |
