1 - 18 of 18 Posts
Does anyone have a link of a good Socket 939 Air Cooler that I will not have to take my mobo out and all that. I dont really want to have to take everything out and put it back in and all that crap...Price is really not an issue..I just want something that will work good.
As far as im aware there is no decent performance coolers for overclocking that do not require the removal of the motherboard for installation.
Unfortunetly most require the mobo to be taken out and installed tight against the HS for saftey and because it helps preformance.<br><a href="http://www.newegg.com/Product/ProductList.asp?N=2000110062+1057715239&Submit=ENE&SubCategory=62" target="_blank">http://www.newegg.com/Product/Produc...SubCategory=62</a><br>
All of these are great , I love my Big Typhoon , but also there's a sale on the Zalman cnps9500, which looks great.
Goodbye
Check out mine, the A.C Freezer 64 Pro.<br><br>
You dont have to take out the mobo as it uses the normal clips to mount.<br><br>
It also performes only a degree hotter then a 9500
Goodbye
Here's it on newegg<br><br><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835185125" target="_blank">http://www.newegg.com/Product/Produc...82E16835185125</a>
AC Freezer 64 Pro. it's a pretty good cooler, cheap and uses the stock clips
Discussion Starter #7
Well I think that I am going to go ahead and get the Big Typhoon...I installed the one in the machine that I built for my dad and it was not as bad of an install as I thought it would be...Ordering today...I just hate taking everything apart...<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Get a Big Typhoon VX then. No motherboard removal, better fan. Costs a bit more, though.
Discussion Starter #9
<tr>
<div>
Originally Posted by <strong>Namrac</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1399589#post1399589" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">Get a Big Typhoon VX then. No motherboard removal, better fan. Costs a bit more, though.</div>
</td>
</tr>
</table>
</div>I cant find a link it it...Can you post the link???
<a href="http://www.thermaltake.com/product/Cooler/Retail/CL-P0310/cl-p0310.asp" target="_blank">http://www.thermaltake.com/product/C...0/cl-p0310.asp</a>
Discussion Starter #12
I was just looking at that and I know the one I put in my dads machine is pretty heavy...Do I need to get a backplate for this or will the small one that came with my mobo work fine.
Many, including me have used the stock plastic back plate. Unless you move it around a lot, for the likes of Lan Partys, it should be fine. <br />
I'm going to be doing a comparison of the BT and the Ultra120, both are fine units but I want to see what the diff is with various fans.
The AC Freezer 64 Pro is easy to install
Umm have you guys forgotten about the Scythe Infinity? It only needs the stock bracket and comes with the mounting clips for all sockets. I have one for sale (check sig) if interested and its cheaper then most.<br />
<br />
pink
Discussion Starter #16
I ordered my BT VX and UPS is showing that it is Out for Delivery so I am just waiting to go home so I can install it..I will let you guys know the results.
Go with the Big Typhoon VX, you wont go wrong if you buy this. I am overclocking on 100% air because I didn't want to mess with water cooling and I have got my 2.55GHz processor down to 40 degrees celcius under full load such as Battlefield 2142, Company of Heroes, and the Need For Speed Carbon Demo. Trust me if you want a good cooler, go with this one. Also, if you are looking to better your graphics processor, go with the Accelero coolers, I dropped my temperature 15-18 degrees celcius from stock cooling <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #18
Just a follow-up...I got my VX installed...Was kind of a pain but worked out...I have my system oc'd to 2.4 GHZ and am running 40C full load do that is a drop of about 7C...Still gotta let the AS5 burn in and I am sure it will drop a little more.
1 - 18 of 18 Posts
