First off I thought I had pretty good air flow considering my case temps are usually stable at 26 - 28c. As soon as I start gaming....WOW! Load temps are about 50 and case temps are about 31 - 33c. I have a Antec 120mm for rear exhaust and a antec 80mm for front intake with a side duct to cpu. I also have a piece of crap power supply that has only 1 80mm fan on the back. My question is this, the current supply only has vent holes on the rear(cable side). They are pretty obstructed by the cables and about 2 inches of clearance from the cdroms. Would a power supply that has a bottom fan and a rear fan be better for air flow in the case?
