Air tight PVC threads
3797 Views 8 Replies 7 Participants Last post by  mfb412
i use a custom pvc res, dont get me wrong its great but
i want the threaded cap to be water and air tight
how would i do that?
1 - 9 of 9 Posts
Just use some Teflon tape, that should do it and you can still take it off when you want to.
"Hercules Pipe Dope" is about the best I think, its nice and thick, its a little more expensive at $5-6 a roll, but a roll will last you for years if your not a plumber..
..It comes in a little flat can.
Teflon tape FTW! You can buy it most anywhere.. they call it Thread Sealant tape usually.
It's like 2 bucks at any hardware store.
Edit- Wow, Ira's fast!
The trick with the tape is to not put too much on. It is actually not a 'sealant' but a lubricant for the threads. One or 2 times around the threads is all you need. One thing I've used on threaded pvc that worked very well was silicone. I just put a bit of it around the threads. ( I was out of pipe dope and was too lazy to run to the store....
) It has worked for me pretty well the few times I've done it.
well in response im actually looking to seal the treads
Assuming your reservoir is made from pvc pipe with a threaded fitting on the end, the threads should be water tight. and tape will help with this.
you can also use o rings. just be careful not to squish them too much!
afterall, a bad Oring was what made a space shuttle go down :O
1 - 9 of 9 Posts
