Should probably be "a MCR-320", but "an" sounds better.
Anywho.
I'm dubbing out the fans in my Gigabyte Aurora for different colored ones. I have three 120mm fans in the Aurora that needs to be changed -- all blue. There is a pretty good chance by December that I'll convert to water cooling with the Swiftech MCR-320 (unless any similar priced objections).
So, instead of buying orange LED fans for my case, then turning around and buying more fans for the radiator, I was thinking about just moving the fans from the case to the rad, and the new fans in the case so that I won't have to buy two sets of new fans.
So -- my question; are three, 40CFM fans good enough for an MCR-320 radiator for a Core 2 Duo? What about a Quad? I'm not really going for quiet (they are damn near silent, though), it's just that this is a way to save some money. If more CFM is needed, or if cooling performance goes down the tube from lack of airflow, then I'll upgrade to higher ones, but if they'll do fine, I'll use them until I have money to buy some higher end fans and hook them up to a fan controller or something.
(BTW - somewhat unrelated question. I'm going orange LED case fans. Maybe. I'm wanting orange UV dye, but I can't really find any, and when I do it's in some huge amount for about $30. Could I just buy some red and yellow and make orange, or do dyes not mix well? And, in your opinion, should I go orange UV fans, or orange LED fans...? For air cooling I'd think LEDs would look better, but if my fluid is going to be orange UV, I'm thinking the fans would look better UV as well.)
Decisions, decisions...
*edit*
Spelled radiator wrong once in the second paragraph. Annoyed me. >.>;
Anywho.
*edit*
