AT-1 Phase 2: Cheap Mod "Spray Painting"
Hey folks, I'm new to the OCN, I'm pretty stoked to be here and share the progress on my budget rig modding/building. Here's a brief story of what got me started; As my parents loved the color white on everything, I naturally got attracted to white colors during my high school days. Our house has literally everything white; white wall, white piano, white table, white couch, literally everything except the wooden floor. I must say though, it was pretty annoying that I could not touch walls as it would get stained instantly, otherwise my parents would neg non-stop.
8 years later, I purchased a white 780T Case and the color preference has hit me once again. As I realized the color of Sabertooth's heatsinks weren't in sync with the case, I decided to research for a whole week if painting on these heatsinks are possible and yes, they are!
However most people recommended those heat-proofing paints that are usually sold in Auto Shops. As I was on a tight budget, I said screw it and bought the normal cans of spray paints from the Home Hardware Store; Rust Oleum: Painter's Touch "Ultra Cover x2" were the available ones at store that specified safe temperature of around 90C after the paints were applied.
I purchased a "Painter's Touch" White Primer and a Beauti-Tone's "Rust Coat" White Semi-Gloss, as well as a bottle of "Easy Off" to strip any existing materials that I don't want under the paints, which i left the heatsinks drowned in easy off, and after while it came off very easily. Once they were all cleaned and dried properly, I made sure to tape the area that I don't want to paint. For example, the bottom where the thermal tapes are attached, unless you are planning to buy one and reattach them. Once that was done, I started painting it inside a ghetto box which took me hours to dry each layers properly and 24 hours to dry everything completely. I did get impatient and went ahead 3 hours earlier and start using AT-1 (name of first AlbinoTech model). This is what it looks like:
Also, the bit of red on the ram sticks aren't melted paints. I did screw up at the bottom of the heatsink while trying to wipe something off, but I honestly don't care as it will be replaced with actual white ram with led on. It's been 3 days, running for 6~10 hours a day and the painted surface seem to be perfectly stable. The North Bridge runs at 33C idle, 40~42 under load, and the South Bridge runs at 29~30C idle, and 33~36 under load. For some reason the idle temps are few degrees lower...wut
[Update] It's been a week and the texture of the paint hasn't changed a bit. Success! Now for the long term..
Now I'm trying to make a decision on painting the interior fully white or not (except for the wires), mostly depending on if I decide to build Motherboard and PSU cover, which will be also white.
Once I make a decision, I will work on it and will keep it posted
Feel free to leave questions or suggestions.
Here's the layout for the future mod before/during summer of 2016:
- Motherboard Socket Painting
- Case Interior Painting
- Building Motherboard/PSU cover, out of Acrylic vs Carbon-fiber, either way painted to white.
- Painting AIO cooler's hose and part of its pump to white (optional)
- Custom Loop (Too high for the budget at the moment)
Future Hardware Upgrade:
- Second GTX 970 (very soon)
- NZXT Kraken G10 White GPU Bracket [x2]
- H55 [x2]
-1TB SSD (waiting on sale)
Thanks for reading, stay tuned!
- H55 [x2]
