1 - 4 of 4 Posts
I'm trying to install my drivers for my onboard sound thingy. I downloaded the correct Realtek AC97 drivers, when i try to update my sound controller to get sound working, it tells me to select certain files. Right at the end, it tells me to select the file 'Alcrmv.exe'. I do so, then my computer restarts. If i install this driver in safe mode, it installs, but each time i try to log into my computer, it restarts..<br>
I tried selecting the file from Windows/system32/drivers. AND, in the Realtek folder...<br>
I'm really annoyed because now my sound doesn't work.<br><br>
My motherboard is an Asus P4S800 - MX<br>
and i have a SiS chipset
CHECK WINDOWS UPDATE FOR NEW UPDATES. dID YOU JUST DO A FRESH INSTALL OF YOUR os? tRY IT AND SEE WHAT HAPPENS AFYTER YOU REBOOT FROM YOUR UPDATES... oops, sorry about the capslock
Yep. Fresh install of WIndows Home Edition.<br>
I'll keep installing the updates..But yeah any other ideas?<br><br>
Edit : All the upudates are just Security ones...<img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!">
1 - 4 of 4 Posts
