almost there :)
334 Views 8 Replies 4 Participants Last post by  Korruptive
ive figured out alot of things on my quest to perfect my computers performance. heres the deal. when i leave my cpu clock at default speeds 2.4GHZ my video card runs at pci-eX no problem.....
when i set the FSb to like 450 which makes my ram run at 900MHZ with a multiplyer of 8 giving me a 3.6 GHZ overclock. which is good. however once ive done this my video card is only going at pci-eX1.... and i dont know why.. how could i maintain my overclock and still get my video card to run at pci-ex16 and not x1 like it has been for the past 8 months and i didnt know about it.
1 - 9 of 9 Posts
DO you have anything in the BIOS set to "auto" if yes the take it off and set them manually.
yes i do, but those are like northbridge and southbridge voltages and stuff, and i dont kow what they aer sopsoed to be set at
thats it!! i set the northbridge voltage to about 1.45 or sumthin and the southbridge voltage to 1.6 and now shes running at 16x. becnhamrking now
MUCH BETTER, ITS OVER DOUBLED. but is it about right for my system?
now that ive gotten the pci-e situated out,
what woud be the best overclock to get me to 3.6ghz
lower muliyplier higher FSB? ot lower FSB and higher multiplier.
options 400FSBx9
450FSBx8
515FSBx7
600fsb x6
yea it says these GPU can go up to 130C.. and ofcourse 96 when i was running the benchmarking stress test
Obviously if you could keep it a lot colder it would run a lot better, heat = resistance, resistance = less performance.
1 - 9 of 9 Posts
