1 - 7 of 7 Posts
Right, so I am looking to get a laptop to take with me places and use for school.
Desires:
Good battery life
Able to play HD content, at least 720p, with no problems
No problems running Linux distros (so a wireless arrangement, really)
15.6" or smaller, pref smaller
Windows 7
Don't Need:
Dedicated graphics, Blu-Ray or DVD, silly gimmicks that I will never use, netbook, or a tankbook.
So in short, a reliable laptop that isn't too big that can playback HD content (I'm sure this won't be a problem for most systems) and comes stock with Win7, even though I plan to install Linux alongside it. Integrated graphics are fine, but extremely low end dedicated ones work too, especially if they'll help decode HD media.
Speakers, not a big deal, I'd be using my headphones anyways. Integrated audio all the same, I'm sure I'll be crying about how my FLACs don't sound as good as when I play them in the sig rig.
I realize this wouldn't be hard to find on my own, but surely there must be ones that are KNOWN to be good.
Looks like all makers have what you desire but in terms of quality.. Hmm.. Dell & IBM is what you should be looking for I guess..
Discussion Starter #4
Originally Posted by jacobroufa
I know you said 15.6 or smaller... but take a good long look at Dell Studio XPS 16. Best laptop screen ever and it doesn't feel like a 16" notebook. Good battery life, great reviews all over the net. Plus it's way upgradeable so you're future-proof.
I meant that area, really. I could have said "Nothing 17 and bigger" but I guess that was implied.
Either way, Dell starts those at nearly a grand, and I don't think I need or even want a laptop worth that much.
I figured. All I really knew is that I wanted to stay away from HP.
How about my laptop? Asus UL30A. It uses the CULV Core 2 Duo w/ 4GB DDR3 RAM and an Intel GMA 4500. Has a 13" screen, is thinner than a MacBook, and is very very light. and depending on the model you get, 320 or 500GB HDD.
On my old HDD, I pulled 10 hours out of it on the battery. With my SSD, I can do 10:30.
You usually can find it used/refurbished on ebay for $550 (got mine for $500).
Asus is all-too-often overlooked... sadly. They make great machines. Good recommendation.
Originally Posted by IBuyJunk View Post
Dell Studio 14z!
a good machine too. I looked at this one before I bought my xps13
1 - 7 of 7 Posts
