EDIT #2: It's back again. I tried what I thought previous worked (control panel). It didn't this time. I played a couple games and then it happened again. My ingame hertz went up to 120Hz (windows is 100Hz) so i set it back and now it takes forever to alt tab again. Windows res and Hz and ingame's are the same.
EDIT #1: Sorry I was too fast posting this thread. I seem to have have fixed my problem myself already. I put GPU in out PCIe slot and went to Control Panel -> Display -> Screen resolution and clicked detect and identify (think control panel thing fixed it).
Sorry again for posting to hastily.
I play Bf3. When I alt-tab it takes about 5 sec to get to my desktop and another 5 sec to get back into the game again. This also happens when I alt-F4 to quit the game, again it takes about 5 sec for my browser to appear.
I recently got an new monitor. BenQ XL2411T. First day alt-tab worked fine. Set my windows res to 1280x720 @100Hz and my ingame res to 1280x720 @100Hz.
I installed Lightboost using a program called CRU to trick my monitor into thinking its an Asus or something along those lines. This work good for a couple games. Then I heard a windows hardware disconnected sound and then a connect sound. So my monitor dc'ed I think. I got problems with lightboost not working and after I tried installing it again it only worked while I was ingame (Which I thought was strange). This resulted in the long during Alt-tabs in the first place I thought. Well I dc'ed my monitor while ingame to get rid of Lightboost ingame.
Now I have same res and hertz windows and ingame, no lightboost + I reset monitor, and it still takes longer then it should to alt-tab.
When I set my ingame and windows res to 1080p @120hz (which in optimum res according to OSD of my BenQ) the alt-tab is faster, but I notice when tabbing ingame it flickers a border (like you would have if you played windowed mode) for less then a sec and then goes ingame fullscreen. It doesn't do this on 720p 100Hz, there it takes forever.
GPU - GTX 560Ti. Might be dusty a bit, but temps go 56C highest.
Might it be a faulty PSU problem somehow?
Could it my memory as it takes some memory to alt-tab I read somewhere? I have 8GB (2x4GB identical), compatible with board.
Anyone has any idea what I should do to get alt-tab to work properly again on my res (720p @100hz)?
Thanks in advance
Thanks in advance
