1 - 20 of 36 Posts
i bought an 8400gs becouse i thought i only had PCI slots becouse i have an old comp and 8400gs was the best pci card i could find. and i just opened up CPU-Z and saw that my motherboard can take PCI-e x16. can someone please tell me if i am able to slot in PCI-e cards? my motherboard is Intel D915GAG
thank you,
It would be best just to open your case and look. CPU-Z may say so, but OEM manufacturers will order motherboards and ask for the PCI-e slots to be removed. The PCI-e lanes are there, just no way to actually use them.
^^That's my user name^^
I would see if the company will take it back, with a full refund. That is, if you buy a better GPU from them. Offer to buy something before you return it. I'll be they will give you a shipping label. Explain about the PCIE.
Your not an idiot. Though looking inside your case you should know what a pcie lane looks like
Initializing...
You're not stupid its just a mistake thats all. I guess you got to return the card and get like 9600GSO or something.
Originally Posted by 8400GS
hmm im intrested :/ slightly i can tell you some specs now. these are OC'd btw 800mhz core 1800mhz shader 500mhz memory :/
(btw thanks for help guys)
Is it the 512mb version?
Discussion Starter · #14 ·
yeah to answer most of these, when installing my 8400gs i saw the PCIe slot but i thought it was a PCI-x so i didnt bother asking for refund at the time.
Well, I have 2 8600GTS in my wife's system, where there is no need for 2 cards...and my mother needs a PCI card. Let me know if you want to trade. Personally I would return it if at all possible and get a 9600gt/GSO. Trading with me is a good 2nd option
He wanted a quick answer. He probably didn't expect so much help.
I've had many questions on many forums. This forum gives the fastest replies. Plenty of good answers. (and a few ******ed ones to even things out)
1 - 20 of 36 Posts
