1 - 20 of 29 Posts
i keep getting this message/popup report, and it looks quite worrying
are my banking details etc. really at risk from this.am i being hacked?
or is this an attempt to get me to download something else?
http://www.overclock.net/attachment....1&d=1135609304
how serious is this, and how can i get rid of it
spybot, and adaware se, have not detected/removed it.
i also found "mssearch.net.exe" in my processes.
1. DONT USE IE. www.mozilla.com, download firefox
2. Download SpyBot AND Ad-aware, update definitions, scan, delete.
3. Download virus protection like AVAST and do a complete scan with latest definitions
4. Go to add/remove programs and make sure you dont see any programs you didnt install, if you do UINSTALL THEM
I would go to my program files and delete the directorys to, but only if your sure not to delete the wrong stuff, maybe get a registry cleaner to (?)
That is a worm, not spyware. Its a virus.
You might have to do the virus scan in safe mode also, good luck!
http://[email protected]
Don't use your e-mail untill you remove it.
As far as to your risk level... could not say.
Best to change any passwords on any banking accounts after you remove it to be sure.
Its bogus. I just went to the webpage in your screen shot and it gave me the exact same page, even said the exact same ip had control of my machine and I know there is not any thing on my machine.
You guys need to go get some virus protection and always have full-time virus protection on. Then it detects them before they can do harm... usually..
yeah, usually if you get a popup with Microsoft Internet Explorer in the title bar and you are using Firefox it is probably just spam.
Discussion Starter #9
i have full Norton Antivirus Software, but this stuff still gets in, i always have it on, and my firewall.
i didnt run a scan in safe mode yet, will do asap.
You shouldnt get popups in firefox
its a nice habit to get into...you run a quick scan for viruses every other day, and run spyware programs once a week or more..takes like 5 minutes and could save you hours in the long run.
You update your definitions daily? I had Norton for some time and it usually stopped them or removed them in time. But always atleast detected them.
Discussion Starter #14
i do the daily routine, but something has slipped through here.
Well since everyone is getting that message it might just be false information trying to get you to buy a program, You might not even be at risk. And to remove mssearch.exe prob do this... Check add/remove program..check program files or the program files directory for a folder with that name. Then delete it. If its not there go to start>run>msconfig>startup and see if its listed in the list and uncheck it
Discussion Starter #16
hmmm , its not in any of those places, it IS listed under processes in win/tak/magr, but if i remove it, it just immediately starts again.
all programs> startup?
if its loading on startup theres gotta be a .exe or something causing it to. And all startup programs are in the msconfig under startup/services
try checking the hide microsoft services in the services tab and see whats there..i doubt it tho.
maybe a screenshot of the "STARTUP" tab and everything listed? See I only have 4 checked
Discussion Starter #19
Download and run CCleaner.
http://www.ccleaner.com/
It not only is a great cleaning utility, but it let's you control you startup programs and uninstall anything.
1 - 20 of 29 Posts
