Oh no not another bottleneck question.
Yes sorry, I know this is fine, but I had just a few thoughts,
CPU: AMD Phenom II x4 965 3.4Ghz (stock)
-Idle temps: 35-38c Load: 50-55
GPU: ASUS GTX 460 1GB (stock)
-Idle temps: 23-26 Load: 45-49
RAM: 2x2GB DDR2 800Mhz
CRAP I know, I shall upgrade to DDR3 1600 2x4GB once I get new mobo! But the ddr2 is bottleneck right?
PSU: CM 500w extreme.
HDD: 2x1TB WD 7200rpm 3gb/s
OS HDD: 320 GB 7200 rpm 3gb/s
OS: Windows vista home prem. x64
I do not wish to upgrade to win 7. I tried 7 I did not like the UI as much.
When I play BF3 at med settings, about 45-60 FPS (1920x1080) The RAM goes up to 3.85gb used, so 4 is not enough.
SO, apart from the RAM, am I in bottleneck right now?
-Thanks for the help
