1 - 20 of 24 Posts
That's bad
Try adding the "-forcegpu nvidia_g80 flag"
And if you run SMP, you'll be able to get ~2k on the CPU, vs ~200 PPD
Originally Posted by mmx+ View Post
That's bad
I did the force nvidia flag because its sli and i read to do that in the guide.., how will it know which is which?
Also i am using SMP...at least thats what the guide said.
That's not SMP, at least not done correctly
You need a shortcut to the exe with the -smp flag. Delete the WU/queue.dat, create the shortcut, and launch it with that.
The GPUs will also need shortcuts, you'll want "-forcegpu nvidia_g80 -local -verbosity 9 -gpu 0" on the first shortcut and -forcegpu nvidia_g80 -local -verbosity 9 -gpu 1" on the 2nd. Remember you also need unique machine IDs
Discussion Starter #5
English please. I dont speak spanish. Also i made shortcuts for the GPU's, but in the guide it didnt have that verbosity thing(SLI guide) +I just changed the cpu client to SMP. No idea what unique machine id's are, it didnt give me that option.
Just add the flags I have, they're what you want.
Delete the client.cfg files for both GPUs. When you run them, you'll be asked to re-configure. When it asks "change advanced options" enter yes. One of the things you can then set is the machine IDs, choose something like 2 and 3
Originally Posted by MR KROGOTH View Post
Mmk, but still, whu does my GPU0 client have the "unstable machine" thing?
Likely because you didn't set different machine IDs
Excellent
Mind posting a SS?
Sounds good
Mind posting your log files & client.cfgs? And you are using the shortcuts with flags, right?
Does it work just running 1 GPU?
No problem
Glad it's working
1 - 20 of 24 Posts
