Am I killing my video cards?
414 Views 9 Replies 5 Participants Last post by  Somenoob
So I'm going to get another one of these
http://www.newegg.com/Product/Produc...82E16814102759
The problem: My motherboard isn't PCI-E 2.0
http://www.newegg.com/Product/Produc...82E16813131196
Am I massacaring my video cards because of this?
1 - 10 of 10 Posts
How on earth do you think would would be massacring your video card?
It will run perfectly fine.
Well I'm worried since my second pci-e slot is only 4x that I'm going to kill my second gpu in terms of performance.
Would it be worth my time upgrading to say
http://www.newegg.com/Product/Produc...82E16813136053
for the increased performance?
Well yes the 4x slot will hurt the second card a bit, but it's been shown time and time again that it has very little performance effect.
If you want to get the motherboard go for it. It's a DFI which is much nicer then ASUS in my books.
well i tried comparing my card on PCI x1 and x16... Played call of duty on 1 and i barely got 20fps.. with 16 i got 90-100 so there will be a difference between 4 and 16...
But arn't I throtteling the pci-e 2.0 card on my motherboard?
Haha nope.
Video cards don't even use all of the x16 PCI-E 1.1 bandwidth, they're not even starting to dip into 2.0 territory.
Hrm...I guess I'll buy a 2nd video card then :-D
Go for it! It'll do nothing but help performance
I disagree.
Crysis
DMC4
Supreme Commander
UT3
WIC
Soure:http://www.legionhardware.com/document.php?id=761&p=8
That 4x slot will hurt performance.
EDIT: Charts aren't working for me. Just look at the article.
1 - 10 of 10 Posts
