I strongly recommend you get this mainboard which is the right budget.
Originally Posted by GAMERIG ![]() I strongly recommend you get this mainboard which is the right budget. |
Originally Posted by sutty86 ![]() ive found that mobo at around £40 but its micro atx and only has 2 ram slots what do you think to this mobo https://www.pricelover.com/product/GA_M720-US3/ would it work well with the phenom2 x2 black edition 550 |
Originally Posted by firestormcomputers ![]() I bought that board for a budget build and it is amazing, but it does only use DDR3. |
I'm asking you the third time , do you have a PSU/Case/Dvd-drive from your old parts that you can use for this build? It's possible to build a pc without a case and dvd, but psu is important , and you can't go cheap with PSU's |
Originally Posted by sutty86 ![]() No ive never had another build, ive owned laptops previous years, just bought me a Gigabyte GA-M720-US3 what do you think? |
