1 - 20 of 51 Posts
Hello, I'm kinda new to the Overclock.net<br />
can i post my problems here?<br />
<br />
if so -<br />
<br />
Back in august i built a new system (First Time)<br />
i did not have much time to use, and everything seemed fine<br />
I only had to change video card bios, because the fan was running at full 100%.<br />
This weekend i had time to play some games, and be on internet.<br />
After about about 4-6 hours, the computer would just randomly restart. I googled, and found that it could be BSoD, i disabled automatic restart.<br />
Now the computer would just freeze or i would get a BSoD (After 4-6 hours). <br />
Also when the computer freezes, everything keeps on working, Case fans, graphics fan, cpu fan, hard drives, usb ports, and etc.<br />
<br />
Memtest found no errors is memory (Corsair XMS2 Twin2x 2048 6400c4)<br />
<br />
All of my drivers are up to date, and i updated MB bios too.<br />
Different forum post say diiferent things.I really don't know what to do<br />
PLEASE HELP ME<br />
<br />
thanks<br />
<br />
Specs:<br />
AM2 ASus m2n32-sli deluxe wifi<br />
Corsair XMS2 Twin2x 2048 6400c4<br />
Antec TruePower2 PSU 550vv<br />
X2 3800+ (no oc)<br />
XFX PV-T71G-UCF7 GeForce 7900GT 256MB GDDR3 PCI Express x16 Video Card<br />
LITE-ON 16X DVD±R DVD Burner W/ LightScribe<br />
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB<br />
Microsoft Windows XP Media Center Edition 2005 w/Update Rollup Release 2 OEM 1 Pack - OEM
Welcome, Nice rig
<tr>
<div>
Originally Posted by <strong>BenHagerty</strong>
</div>
<div style="font-style:italic">Welcome, Nice rig</div>
</td>
</tr>
</table>
</div>thanks, too bad it has a GLitch
Hi and WELCOME <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
My take on things since it's not OCed and you've checked the memory...<br />
The only I can't but will comment on <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> is the PS...<br />
Can't coment on it because I don't kn ow what it is ...<br />
Will, coment that it sounds like that may be you problem...<br />
Why, your saying about 4-6 hours gaming... that is the PS is under load which generates heat, heat and load brings in the question as to wheteher the PS can take the load of the components you have.<br />
<br />
So either you have one of the early 7900GT that have crappy ram and it's the cause under load or ...<br />
The PS can handle the load of the entire system when it's being put under load!
Discussion Starter #5
<tr>
<div>
Originally Posted by <strong>The Duke</strong>
</div>
<div style="font-style:italic">Hi and WELCOME <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<br />
The PS can handle the load of the entire system when it's being put under load!</div>
</td>
</tr>
</table>
</div>thanks for reply,<br />
sometimes it freezes when the computer is on just idle<br />
<br />
here is my psu<br />
Antec TRUEPOWERII TPII-550 ATX12V 550W Power Supply<br />
it is similar to this one <br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817103930" target="_blank">http://www.newegg.com/Product/Produc...82E16817103930</a><br />
but with 550w
Well, I would think that PS can handle it, but still check the 3.3,5 and 12v rails... no more 5% varable is ok but 3% oir less is best.
Discussion Starter #7
<tr>
<div>
</div>
<div style="font-style:italic">Well, I would think that PS can handle it, but still check the 3.3,5 and 12v rails... no more 5% varable is ok but 3% oir less is best.</div>
</td>
</tr>
</table>
</div>it says +- 3% on the psu
Discussion Starter #8
also i was thinking, would a bad psu give you a BSod, doesn't tha has to do something with windows drivers
He meant check the volts in a monitoring program, cant think of one off hand, maybe speedfan.
Discussion Starter #10
<tr>
<div>
Originally Posted by <strong>toad12585</strong>
</div>
<div style="font-style:italic">He meant check the volts in a monitoring program, cant think of one off hand, maybe speedfan.</div>
</td>
</tr>
</table>
</div>thanks,<br />
/feel like a newb <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
here is stuff from speedfan<br />
vcore1: 1.38v<br />
vcore2: 0v<br />
+3.3v: 3.30V<br />
+5v: 4.92v<br />
+12v: 12.03v<br />
-12v: 1.96v<br />
-5v: -8.78v<br />
+5v: 4.76v<br />
vBat: 3.07v
ok if you watch that for a little bit did any of those voltages fluctuate at all, like say vcore going from 1.38 to 1.42 or dropping to 1.34 or something like that on any of those
Discussion Starter #12
<div>Originally Posted by <strong>MADMAX22</strong></div>
<div style="font-style:italic;">ok if you watch that for a little bit did any of those voltages fluctuate at all, like say vcore going from 1.38 to 1.42 or dropping to 1.34 or something like that on any of those</div>
</td>
</tr></table></div>
ok i'll watch
Discussion Starter #13
</td>
</tr></table></div>
no,<br>
nothing changes, everything stayed the same<br>
didn't even move by .01
Don;t think its the PSU then, maybe you got one of the bad 7900GTs, what color are the capacitors on it? If they are purple, you should be fine with that also, if I remember correctly...
Discussion Starter #15
<div>Originally Posted by <strong>toad12585</strong></div>
<div style="font-style:italic;">Don;t think its the PSU then, maybe you got one of the bad 7900GTs, what color are the capacitors on it? If they are purple, you should be fine with that also, if I remember correctly...</div>
</td>
</tr></table></div>
well, i don't see many capacitors, but some are black some are silver.<br>
here is an image<br><a href="http://images10.newegg.com/NeweggImage/productimage/14-150-150-03.jpg" target="_blank">http://images10.newegg.com/NeweggIma...150-150-03.jpg</a>
I can't tell from that pic considering its not your actual card lol. But I believe all of those are supposed to be the purple ones. If they aren't, your vid card might be your problem. There was a lot of posts a while back about bad cards (7900) When did you purchase this card?<br><br>
EDIT: Then again I could be completely off, but I'll google around
Reactions: kuba
Here we go...<br><br><a href="http://www.overclock.net/graphics-cards-volt-mods/102385-7900-gts.html" target="_blank">http://www.overclock.net/graphics-ca...-7900-gts.html</a><br><br>
EDIT: ALso, do you have another card you could use in the computer, to possibly rule out the video card problem?
Discussion Starter #18
<div style="font-style:italic;">Here we go...<br><br><a href="http://www.overclock.net/graphics-cards-volt-mods/102385-7900-gts.html" target="_blank">http://www.overclock.net/graphics-ca...-7900-gts.html</a><br><br>
EDIT: ALso, do you have another card you could use in the computer, to possibly rule out the video card problem?</div>
</td>
</tr></table></div>
yeah, my video card has purple capacitors,<br>
just in case, tomorrow morning i'll go BB or CC to buy cheap nvidia and ati card.<br>
i read on some forum, that m2n32-sli have problem with nvidia cards!?<br>
may be , still its a good idea<br><br>
i bought it in august,<br>
you can still buy them, now they are $180 at newegg<br>
if the card is not causing problems, i probably buy a second one for the sli-thing
Worth looking into.<br><br>
ALso I would assume that you've checked to make sure everything is seated properly, and that your temps are stable, and not too high. Cant remember whether you stated that or not. ANywho, Ill google around some more using your system specs to see if I cant find anything.
Discussion Starter #20
<div style="font-style:italic;">Worth looking into.<br><br>
ALso I would assume that you've checked to make sure everything is seated properly, and that your temps are stable, and not too high. Cant remember whether you stated that or not. ANywho, Ill google around some more using your system specs to see if I cant find anything.</div>
</td>
</tr></table></div>
the temps are good<br>
cpu 40c idle 47-50 under load<br>
mb 30 idle 32 under load
1 - 20 of 51 Posts
