1 - 20 of 64 Posts
Title. Will the new 8 core CPUs be under $300 or $300? The lower end module, like a 1055T instead of a 1090. And motherboards. Under $250 for a high end overclocker?
More than likely yeah...
The mobos Im sure there will be some epic ones for 250-300, but most will be 100-230, and then the cheaper ones.
$349.99
Probably sleep deprived
Originally Posted by Enigma8750 View Post
I think 329.99 or 369.99
Thats what im betting as well.
Depends on how they compare to Intel and if they're released before or after sandy bridge and again how well they compete with Intel will be the decided factor on price point.
If they kill the i7's before Sandy Bridge comes out expect $1000 CPU's, if not wait for Sandy Bridge >.>
Lower end 8 core should be $200 or less
This is AMD so it will be priced per performance and market competition (well, same goes for any company really), 8 core bulldozer should be 25-40% faster than the current 1055T or 1090T
There will be advantages over the current 6 cores with the 8 cores in terms of speed but it will not be insane. Keep in mind that there are a total of 4 256-bit FPUs versus 6 128-bit FPUs in the Thuban generation, maximum possible speed up in that area is 25% but I doubt it'll be reaching the theoretical
negative you will probably never see a $1000 dollar amd desktop cpu ever. Thats intels job.
I take it you missed the A64 FX days
nope They wernt nearly as bad as intel was i know they were high but there was no 1000$ cpu crap that intel likes to pull.
But,that's when A64 FX was that much better than P4 intecrap crapburst.
Only 25% faster than a 1090t?
1090T goes for around $315 - and compared to the pricing of 1055T being around $200, it is approx $115 more.
So I'd hazard a guess that that Zambezi will start at approx $100 more then the 1090T. But When Zambezi is released, I'm sure the 1090T will drop, and so the Zambezi's culd start around $300.
Saying that, it is all guesses and speculation - if Zambezi performs better then expected, I'd think AMD will up the price even further, and the faster 8 core Zambezi's could easily be over $500.
No way to do know. We'll just have to wait and see.
anyone got any links of the specs of the 8 core?
I have about $500 saved so far. I'm aiming for $700 for CPU+Mobo+RAM
Discussion Starter #20
Im aiming for $600.00 CPU/RAM/Motherboard and another $150.00 for a 6770, then $25.00 for a PSU and $50.00 for a hard drive.
1 - 20 of 64 Posts
