1 - 11 of 11 Posts
Originally Posted by Bradey
if i run my cpu at 100% on all cores i he 65c stable
i need a new cooler
these are my options
1.
i get a x4 stock cooler from some person here that is not using it.( i will pay for postage and handling.) (Canberra, Australia.)
then when i get the money i goto water cooling
2.
CoolerMaster GeminII S
3.
Noctua NH-U9B SE2
4.
CoolerMaster Hyper TX3
5.
Scythe Katana 3 CPU Cooler
6.
Thermaltake ISGC-400 CPU Cooler
7.
Scythe Kabuto CPU Cooler
8.
Scythe Big Shuriken CPU Cooler
i am getting these from www.pccasegear.com
thanks
ps. if you have any better options please say, but these are the critiea
1. must be smaller than 146mm H
2. must post to austraila
I looks to be that you wanted post in the wrong place. Probably because you don't have enough reps to make this request in the proper place. Both transgressions are against the TOS.
WHAAAAA
Where's the Xigmatek Dark Knight?
Seriously, I find that after around 20 minutes of using it, it was a great choice
The Dark Knight is too tall for his case. If you're planning on going watercooling, I say stick with the stock cooler and don't bother with air. It will just be less money you could have saved for the Water cooling.
this
i will only go water cooling if i can get a cheep air cooler
i don't need to go water cooling it is just an option
the cooler i have does not work, i get to 65C just by using all cores in about 2 sec. i have unlocked my 3core to be a 4 core
Unlocked Phenom II X4's usually have faulty temperature readings.
As far as coolers go, I'd probably go with a Scythe or Noctua product on your list. Googling for specific reviews will give you an idea of which is best.
eh, I don't think he's trying to post a WTB thread here. Looks more like a need help thread to me.
i choose to use a ir temp probe
I see. It's not surprising that the stock cooler can't handle all 4 cores.
I just checked out a review for the Scythe Kabuto, it looks like a solid cooler. They were able to overclock an i7 920 to 3920 ghz with 1.35vcore, a chip that produces more heat than yours.
http://www.xbitlabs.com/articles/coo...he-kabuto.html
1 - 11 of 11 Posts
