am3 vs am2+ BS ... why not make it simple....
2542 Views 11 Replies 10 Participants Last post by  elito
does this:
http://www.newegg.ca/Product/Product...82E16819103471
fit on this?:
http://www.newegg.ca/Product/Product...82E16813131363
if not... when will decent BE edition AM3 cpu's come out?
this year or not?
1 - 12 of 12 Posts
No, I believe the am2+ CPU's can't run ddr3, and AM3 motherboards require it.
I'm not sure when they're releasing.
Edit: I think the AM3 CPU's will support ddr2 and ddr3.
My board is AM3 but only supports DDR2.
It's not AM3 then. It's AM3 ready
god amd are slow with this story, ima just end up with an i7 if they dont hurry up a bit.
it's march now. the new chips are set to launch anytime soon.
Yes, correct.
The motherboard and cpu prices at Newegg have really jumped in the past couple of weeks. I paid just over $400 for my cpu and MB in a combo deal.
i believe the 945be is set to be released in april the 925 i believe was suppose to come out end of last month but that didnt happen so there could of been a push in release dates
this year or not?
I think my chip is decent.
THE PHENOM II 940/920 WILL NEVER RUN DDR3 END OF STORY!!!! ALL OTHER PHENOM II's (AKA AM3) will be able to run DDR2 or DDr3. Sorry for caps just I have typed it several hundred times now. There is a reason the 940/920 are labeled as am2+ cpu's
It is. Very decent actually.
I think he'd be surprised to see the winner when paired up against his E8500.
And to answer the OP's question - No. The 940BE will not work on a DDR3/AM3 motherboard.
this has been answered many many times before, AM2+ boards will be ABLE TO TAKE AM3 CPU'Sif the manufacturers specifies and or/ releases an BIOS update, but AM2+ will NOT be able to use DDR3 mem. unless you can find a hybrid board that does both. AM3 boards WILL *ONLY* take AM3 cpu AND DDR3 mem.
1 - 12 of 12 Posts
