I think for what you want to run (SLI and not TRI-SLI), the eVGA 750i FTW is the best choice. It OCs very well (better then the non FTW 780i) and delivers on performance. The only other drawback to the 750i over the 780i is the number of SATA connections. So if you only need 4, it isnt an issue at all.
750i FTW at newegg (Send them cash):
http://www.newegg.com/Product/Produc...82E16813188026
Here is a decent 750i FTW thread here on OCN:
http://www.overclock.net/intel-mothe...ck-thread.html
Here is a decent review of the board:
[H] Enthusiasts: EVGA 750i SLI FTW Review
Overclocking For the overclocking tests all processors were cooled with a Corsair Nautilus 500 and an Apogee GT waterblock. I used Arctic Silver 5 thermal compound for each processor. Working with the 750i SLI FTW was a great experience when it came to overclocking. If overclocking settings ever failed the board recovered instantly and let me know that there was a problem. Never did I have to clear the CMOS or go through a series of reboots and have to wait for the "watchdog" function to kick in. Other motherboard manufacturers need to take note and make recovery this simple for failed overclocking. This board exceeded all others in this area. For this particular review we tested three different processors. A low end dual core, a higher end dual core and a budget quad core processor. The results for each processor are shown below: Core 2 Duo E8500 Results The E8500 is a joy to work with on the 750i SLI FTW. I wasn't able to set any speed records but I reached a respectable 520.3MHz FSB. While I've seen higher end boards do better I'm really pleased I was able to get that out of a sub-$200 board. I was also able to reach a memory clock speed of 1135.2MHz. I've seen this memory go higher, but the results weren't bad considering the board doesn't support the memory's EPP profiles. The E8500 is obviously a solid choice to pair up with this board. |
