Amazing Memory
408 Views 6 Replies 6 Participants Last post by  atomicfission92
Check this stuff out!
As the World's fastest DDR2, the PC2-9200, in combination with the innovative FlexXLC technology, is considerably the most ground-breaking and unique memory product existing today.
These new modules feature the new OCZ FlexXLC (Xtreme Liquid Convention) heatsink that delivers superior heat dissipation via a hybrid copper and aluminum design alterable between passive air or water cooling.
Among these thermal management advantages, the PC2-9200 FlexXLC also implements a new 8-layer PCB. This facilitates less "crosstalk," consequently enhancing the module's total signal integrity.
The PC2-9200 FlexXLC modules are optimized for the latest cutting edge platforms and will be available in 2GB (2x1024MB) dual channel kits. As part of OCZ's line-up of premium memory, the PC2-9200 series is backed by a Lifetime Warranty and industry-leading technical support. Harnessing the achievement of leading-edge speed, high performance heat dissipation, and enhanced signal integrity, the unparalleled design of the OCZ PC2-9200 FlexXLC is a complete, all-encompassing solution certain to set a new benchmark in enthusiast memory.
* The new OCZ FlexXLC (Xtreme Liquid Convention) heatsink delivers superior heat dissipation via the integrated hybrid copper and aluminum liquid injection system. The FlexXLC module was engineered with this unique "flexible" design to give enthusiasts the unparalleled option to run the modules passively or water cooled. The concurrent use of both technologies (water-cooling) promotes maximum heat dissipation and pushes thermal management of memory modules one step further to keep up with the ever-increasing frequency demands. FlexXLC modules seamlessly co-migrate with any system upgrade to liquid cooling.
**The PC2-9200 series is engineered with an 8-layer PCB with thermally conductive power and ground planes to guide heat away from the ICs and maintain the necessary signal integrity for high-end modules.
***OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.4V ± 5% without invalidating their OCZ Lifetime Warranty.
1150MHz DDR2 @ CL 5-5-5-18
£381.86
1 - 7 of 7 Posts
Cool but expensive. Fast costs money. How fast do you wanna spend?
Well i'm considering going Core 2 Duo sooner or later, but when i do it will be using components that will give me HUGE overclocking ability. At current prices my options are:
Core 2 Duo 6600 (Probably 6700 by then)
Asus P5W DH Deluxe (or one with huge FSB capabilities)
At least DDR2 PC8000
By the time i do upgrade the above would be better based on potential price drops on Core 2 Duo's (i can hope lol)
This is a complete gimmick. There is ABSOLUTELY no reason to WC your memory at this point in time..
Yep this is useless because when extreme overclocking memory the problem isn't the heat its the RAM dying from the pure volts.
Yeah I agree its a gimmick...Yes Ram gets warmer these days but no need for water cooling.
DDR2 runs alot cooler then previous memory. And the chips are only on one side. A simple ran would do just fine
1 - 7 of 7 Posts
