Ok, first of all... I'm aware that it's old, and yes, i have something else but i want it to work so... just give me some help
Ok i have a AMD 2200+ that appears as a 1800 and has a bus speed of 166, i have 1.5GB of DDR RAM that runs at 400Mhz... My motherboard is a VIA KT600 and the BIOS is a Pheonix 6.00 PG... The thing is that the computer is (from time to time) even freezing or crashing (rebooting)... It's very cold outside, 35 - 40 degrees (Celsius) and i thought it can't handle it... So i bought a fan for the HDD (don't ask me why, it seeemed preety hot)... After that, a fan for the cage, still, same thing... Another fan for the CPU (but not an expensive one... 2200RPM)... The thing is that after it's restarting the bios shows the CPU temp at 52-53 degrees... And i guess that something is wrong, and it doesn't have any connection to the fans... I think the frequencyes are wrong so i'm asking you for help
