Originally Posted by acidvirus
I know i have asked this before on my other post but what should i upgarde too ??? antec cooling ?? or somthin ells i was told mabe to put some artic 5 paste on and when i called the same place i got my cpu and mobo put in my tower he told me that 50c is ok AMD is stable all the way to 70c ??? is this right also he told me that i would be able to clock to a 3000+ easly with my board is this true ???
He is right, in some aspects, but his terminology is not correct.
AMD's max on-die temperature ranges between 70-85degC depening on what type of processor you have.
You DO NOT want any AMD to have a MEASURED temperatue of more than 60 at LOAD. The reason I say this is that a measured temperatue is not ON-DIE. On-die temps are hotter than measured temps.
Idling at 50degC is not what a stock AMD should do...ever. not even in a laptop.
If you want to the best in air cooling, get a thermalright SI-97 (if they are avilable) and a good 92mm fan for it.
There are many good ones, but thermalright, thermaltake, zalman, and even coolermaster seem to be the better performers.
If you are familiar with it, you should try reapplying some thermal compound to the die of the CPU. Meaning, take off the current heatsink, clean off the existing compound. Apply a B-B sized dot to the middle of the CPU die, then press the heatsink onto the cpu straight down.
You may buy AS5, or even user less expensive comound for now (any compusa...or computer store should carry generic compound)
9/10 times the amount of compound (or lack thereof) is the reason idle temps are so high.
Any questions? Feel free to ask!
