CPU(s)
Number of CPUs 1
Name AMD Athlon XP
Code Name Thoroughbred
Specification AMD Athlon(TM) XP 2700+
Family / Model / Stepping 6 8 1
Extended Family / Model 7 8
Package Socket A
Core Stepping B0
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 2227.5 MHz
Clock multiplier x 13.5
Front Side Bus Frequency 165.0 MHz
Bus Speed 330.0 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 256 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 2227.5 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A7V8X-X, REV 1.xx
BIOS vendor Award Software, Inc.
BIOS revision ASUS A7V8X-X ACPI BIOS Revision 1010
BIOS release date 04/09/2004
Chipset VIA KT400A rev. 80
Southbridge VIA VT8235 rev. 00
Sensor chip ITE 8712
Graphic Interface AGP
AGP Status enabled, rev. 3.5
AGP Data Transfer Rate 8x
AGP Max Rate 8x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 256 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 165.0 MHz
FSB
RAM 1:1
DRAM Interleave 4-way
CAS# Latency 3.0 clocks
RAS# to CAS# 5 clocks
RAS# Precharge 4 clocks
Cycle Time (TRAS) 9 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC3200 - 512 MBytes
Module 1 Corsair DDR-SDRAM PC3200 - 512 MBytes
Software
Windows version Microsoft Windows XP Professional (Build 2600)
DirectX version 9.0c
