Length : 14h
Handle : 0h
Vendor Name : American Megatrends Inc.
BIOS Version : Version 07.00T
BIOS Build Date : 04/02/01
BIOS starting Address Segment : f000h
BIOS starting Address Segment : 256 K
BIOS Characteristics : (6fcbde90h)
ISA is supported : Yes
MCA is supported : No
EISA is supported: No
PCI is supported : Yes
PCMCIA is supported : No
Plug and Play is supported : Yes
APM is supported : Yes
BIOS is Upgradeable (FLASH) : Yes
BIOS shadowing is allowed : Yes
VL-VESA is supported : No
ESCD supported is available : Yes
Boot from CD is supported : Yes
Selectable Boot is supported : Yes
BIOS ROM is socketed : Yes
Boot From PCMCIA is supported : No
EDD specification is supported : Yes
for NEC 9800 1.2MB 3.5" : No
for Toshiba 1.2mb 3.5" : No
5.25"/360 KB Floppy supported : Yes
5.25"/1.2 MB Floppy supported : Yes
3.5"/720 KB Floppy supported : Yes
3.5"/2.88 MB Floppy supported : Yes
Print Screen is supported : Yes
8042 Keyboard are supported : Yes
Serial Services are supported : No
Printer Services are supported : Yes
CGA video Services are supported : Yes
PC-98 : No
ACPI supported : Yes
USB Legacy is supported : Yes
AGP is supported : Yes
I2O boot is supported : No
LS-120 boot is supported : Yes
ATAPI ZIP Drive boot is supported : Yes
1394 boot is supported : No
Smart Battery supported : No
***************SYSTEM INFORMATION < TYPE1 >***************
Length : 19h
Handle : 1h
Manufacturer Name : MSI
Product Name : MS-6712
Version : 1.0
Serial Number : 00000000
UUID : 0000000000000000h
Wake-up Type : ( 04h ) Modem Ring
***************BASE BOARD INFORMATION < TYPE2 >***************
Length : 8h
Handle : 2h
Version : 1.0
***************SYSTEM ENCLOSURE OR CHASSIS < TYPE3 >***************
Length : 11h
Handle : 3h
Manufacturer Name : Uknown Chassis Manufacture
Type : ( 03h ) Desktop
Version : Version 1.00
Serial Number : 123456890
Asset Tag Number : 0123ABC
Bootup State : ( 02h ) Unknown
Power Supply State : ( 02h ) Unknown
Thermal State : ( 02h ) Unknown
Security Status : ( 02h ) Unknown
***************PROCESSOR INFORMATION < TYPE4 >***************
Length : 20h
Handle : 4h
Socket Designation : Socket-A
Processor Type : ( 02h ) Unknown
Processor Family : ( 02h ) Unknown
Processor Manufacturer : AMD
Processor ID : 000006a0h 00000055h
Processor Version : AMD Athlon(tm) XP 2800+
Voltage : ( 06h ) unknow
External Clock : ( 00a6h ) 166 MHz
Max Speed : ( 0bb8h ) 3000 MHz
Current Speed : ( 0823h ) 2083 MHz
Status : ( 41h ) CPU Socket Populated , CPU Enabled
Processor Upgrade : ( 0eh ) Unknown
L1 Cache Handle :0005h
L2 Cache Handle :0006h
L3 Cache Handle
rocessor has no L3 cache
***************CACHE INFORMATION < TYPE7 >***************
Length : 13h
Handle : 5h
Socket Designation : Internal Cache
( 0180h ) Cache Configuration :
Cache Level : L1 Cache
Cache Socketed : Not Socketed
Location, relative to the CPU module : Internal
Cache Memory : Enabled
Operational Mode : Write Through
Maximum Cache Size : ( 8010h ) 1024 K
Installed Size : ( 8002h ) 128 K
Supported SRAM Type : ( 0020h ) Synchronous Type
Current SRAM Type : ( 0020h ) Synchronous Type
Cache Speed : Unknow
Error Correction : None
System Cache : Unified
Associativity : 4-Way
Length : 13h
Handle : 6h
( 0181h ) Cache Configuration :
Cache Level : L2 Cache
Installed Size : ( 8008h ) 512 K
Error Correction : Single-bit ECC
***************MEMORY CONTROLLER INFORMATION < TYPE5 >***************
Length : 16h
Handle : 7h
Error Detecting Method : ( 05h ) 32-bit ECC
Error Correcting Capability : ( 08h ) Single Bit Error Correcting
Supported Interleave : ( 03h ) One Way Interleave
Current Interleave : ( 03h ) One Way Interleave
Maximum Memory Module Size : ( 0ah ) 1024MB
Supported Speeds : ( 000ch ) 70ns 60ns
Supported Memory Types : ( 000ch ) Standard Fast Page EDO Parity ECC SIMM
Memory Module Voltage : ( 02h ) 3.3V Supported
Number of Associated Memory Slots : 03h
Memory Module Configuration Handle : 0008h 0009h 000ah
Enabled Error Correcting Capabilities : Unknown Error Correcting
***************MEMORY MODULE INFORMATION < TYPE6 >***************
Length : 0ch
Handle : 8h
Socket Designation : DIMM1
Bank Connections : ( 10h ) RAS# 1 , RAS# 0
Current Speed : ( 00h ) 0 ns
Current Memory Type : ( 0500h ) DIMM SDRAM
Installed Size : ( 89h ) , Double Bank
Enabled Size : ( 89h )
Error Status : ( 00h ) Uncorectable errors:None , Corectable errors:None , From the event log:None
Length : 0ch
Handle : 9h
Socket Designation : DIMM2
Bank Connections : ( 32h ) RAS# 3 , RAS# 2
Length : 0ch
Handle : 0ah
Socket Designation : DIMM3
Bank Connections : ( 54h ) RAS# 5 , RAS# 4
***************SYSTEM SLOTS < TYPE9 >***************
Length : 0dh
Handle : 0bh
Slot Designation : PCI1
Slot Type : ( 06h ) PCI
Slot Data Bus Width : ( 05h ) 32 bit
Current Usage : ( 03h ) Available
Slot Length : ( 04h ) Full Length
Slot ID : 0001h
Slot Characteristics1 : ( 0ch )
Slot Characteristics2
CI Power Management Enable
Length : 0dh
Handle : 0ch
Slot Designation : PCI2
Current Usage : ( 04h ) In use
Slot ID : 0002h
Length : 0dh
Handle : 0dh
Slot Designation : PCI3
Slot ID : 0003h
Length : 0dh
Handle : 0eh
Slot Designation : PCI4
Slot ID : 0004h
Length : 0dh
Handle : 0fh
Slot Designation : PCI5
Slot ID : 0005h
Length : 0dh
Handle : 10h
Slot Designation : PCI6
Slot ID : 0005h
***************OEM STRINGS < TYPE11 >***************
Length : 5h
Handle : 11h
Count : ( 02h )
***************PORT CONNECTOR INFORMATION < TYPE8 >***************
Length : 9h
Handle : 12h
Internal Reference Designator : USB
Internal Connector Type : ( 02h ) Mini Centronics
External Reference Designator : Def
External Connector Type : ( 04h ) DB25 pin male
Port Type : ( 0fh ) SSA SCSI
***************SYSTEM CONFIGURATION OPTIONS < TYPE12 >***************
Length : 5h
Handle : 13h
Count : ( 02h )
DOES THIS HELP
