Hi all,
I was given a 470 rx 8gb that was used for mining about a year ago. As I was told the original bios was flashed back but I would need to run the ati pixel patch to get it useable in windows. I have had several different issues with this card and just trying to get it to boot.
First system I tried to get it to boot on is on a msi g77a-g45 mother board with i7 3770. I am unable to get the system get past initial boot. Black screen and no lights. Fans are on. The motherboard has been updated to the latest rev. Attempted to boot with igpu with the card installed and no luck.
I was then at some point given a ryzen5 2600 with motherboard asrock b450M. Now with this I can get the PC to boot and see the GPU in the device manager when I have an additonal GPU to boot with. When I try to install the drivers for the 470 the screen goes black around 30%-50% then does some sort of 'reset' and I can hear the fans on the gpu trying to start up. When I boot into safe mode the GPU is listed in the device manager as a RX 470. The ati pixel patch is able to find the device and patch it.
Even after patching I am unable to boot into windows. In any scenario I do not get any display output from any of the ports 1xHDMI 3xdisplay port.
I don't know the model of this video card also. The stick on the back does not lead to any results on the web. I have attached the photo.
E382
Radeon RX 470 8GB GDDR5
PN 288-4e382-000PC A181000016695
The PSU I am using is a 550W which should be enough.
E382
