AMD 64 2800 OC help
1010 Views 3 Replies 4 Participants Last post by  Inquisitor
Could i please get the main rundown on how to do it thanks, and any risks involved,
Specs:
AMD 64 2800 FSB 1600
512 3200 RAM
80 gig HD
Nvidia Geforce 6800 256 DDR 3 (Pride and joy of my computer) [PNY version]
Albatron K8X00: VIA K8T00/ 8237 FSB 1600 (motherboard)
1 - 4 of 4 Posts
Specs:
512 3200 RAM
80 gig HD
Welcome to the forum, I will be moving your post to he AMD area of the forums so you get some more exposure there.
***EDIT
I suggest downloading clockgen from www.cpuid.com/clockgen
It will help get you started with OC'ing.
Now for the basics. Look at DeathONator's AMD Overclocking Guide, it will help familiarize you with some of the terms that are used on this site.
You're system runs at 200FSB with a multiplier of 9. This gives you a clock speed of 1.8GHz.
In order to overclock, you'll need to raise your FSB slowly, usually in max increments of 5MHz. So, you'll end up trying 205FSB...which would give you a speed of 1.845...if the computer boots up normally, you can try 210..and so on.
Overclocking is an iterative process, meaning its not just "set it and forget it"...you'll need to try many different combinations.
The bad things about overclocking is that it is not for a weak system, and it generates alot of heat.
Better cooling for your CPU is REQUIRED for overclocking.
The secret being 50 degrees C at load is a good number to stay close to or below.
Thats all I got for now...try doing a forum search for "AMD 64 2800"
Ask away.
I've managed to push mine up to 250x9. Thats 2.250GHz. But its different for each person, so just try, take it slow, and let us know what happens!
is the 2800 multi 9?
I have a 3000+ and My multi is 10
I've clocked mine to 2.4ghz on stock cooling
yes please read death's guide
raise fbs as Xavier said
if you can raise your multi to 10
if you start to get stuck up that CPU Vcore voltage .25 or so
1 - 4 of 4 Posts
