Originally Posted by timmay7 if you want a massive cooler that isnt so good on load temps but good on idle temps, and will easily snap your mobo, then get the Thermaltake big typhoon. If you want a "ok idle temp, great load temp" get the Zalman CNPS9500. I can run 2.75ghz (unstable) at 29C idle and 35C load on my 3200 (with, ofcourse, AS5.) this is just my opinion. |
Originally Posted by tuchan Why would you want to worry about the idle temps ![]() ![]() ![]() |
Originally Posted by The Fury Thanks for your help guys, i think i will invest in a zalman cooler. Thats if it fits ![]() |
