1 - 6 of 6 Posts
I just bought a new comp with price as a serious factor and went with socket 754 because of that. Was this a bad choice on my part. I am aware that 939 is better but is 754 all that hideous... people on other forums are making it to sound that way...
much less than 10% difference; ive read it was approximately 5%.
most of the benchmarks ive seen between two equivalent rated, different socketed cpus are practically the same...less than 1% difference.
I would like to eloborate a bit on this and ask for the same socket etc: Is there much of a difference between the 512 & 1MB Cache? I currently plan to get the 3400+ 1MB Cache but it went out of stock on me so since I am not ordering ASAP I will either hold out for the 3400+ or just get the 512.
Thanks,
Late
People have over rated socket 939/940 because of the SLI factor... But in gaming having SLI is the only thing that makes it faster.
If you had a 754 and a 939 with the same components or very similar components and not using SLI you would find it would be about 2 to 3 FPS faster in Doom3 and maybe about 2% 3% faster in encoding a movie.
SLI would give you a jump of about 10 to 15 FPS over the single card depending on what res you set.
Its a much better deal to get 754 and get a decent CPU and overclock.
All the people banging on about 939 being WAY faster dont really know what their talking about.
Reactions: Jeckyl
1 - 6 of 6 Posts
