1 - 20 of 28 Posts
hey, im rly thinking of overclocking my cpu a sempron its running at 1.6ghz. but i am scared.. i might harm it. wat frequency should it be increased by. i need help by the pros. please answer me thnx.<br><br>
ps . i think my ram is damaged because it says 224mb of ram it should be 256mb is there anyway of fixing it thanks<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
ram can sometimes be displayed incorrectly .... Well not incorrectly but slightly different to whats physicaly in the pc. Also if you dont have a seperate graphics card then it could be using shared memory
my graphics is onboard. it is terrible for games i wanna overclock my cpu and buy ram afterwoulds and maybe even an agp video card
Download <a href="http://www.cpuid.com/cpuz.php" target="_blank">CPU-Z</a> and tell us your CPU socket.<br><br>
Also take a peek at the Motherboard tab. and let us know what it says. If you know how to take screenshots, take some and post them for us.<br><br>
That will let us figure out how much your system is likely to overclock.<br><br>
And yeah...not surprised WoW is terrible with so little memory and onboard video. You'd do well to get a non-onboard videocard if possible; the extra 32MB of RAM free would also help.
Discussion Starter #7
here yah go hope it helps<br><a href="http://i33.photobucket.com/albums/d85/dpacovski/cpu1.jpg" target="_blank">http://i33.photobucket.com/albums/d8...ovski/cpu1.jpg</a><br><a href="http://i33.photobucket.com/albums/d85/dpacovski/ram1.jpg" target="_blank">http://i33.photobucket.com/albums/d8...ovski/ram1.jpg</a><br><a href="http://i33.photobucket.com/albums/d85/dpacovski/mainboard1.jpg" target="_blank">http://i33.photobucket.com/albums/d8...mainboard1.jpg</a>
well i would get a gfx card for you pc as a first if your going to play games..... Btw thats why your ram only displays 224mb its cos the onboard gfx uses the same ram as the rest of ur pc
Goodbye
You cant get that ram back without putting in a dedicated video card. "Onboard" video sucks away at your normal ram. What I would recommend for you is to pick up another 512RAM or 256 *BARE MINIMUM* <br />
<br />
What I would recommend is you pick up a video card for that. A nice low end card would be an X1300 or X1600, an AGP 7300GS is another option.
<tr>
<div>
Originally Posted by <strong>Penicilyn</strong>
<a href="showthread.php?s=fb118d83aa0ea05832d812d721028acf&p=1382680#post1382680" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">You cant get that ram back without putting in a dedicated video card. "Onboard" video sucks away at your normal ram. What I would recommend for you is to pick up another 512RAM or 256 *BARE MINIMUM* <br />
<br />
What I would recommend is you pick up a video card for that. A nice low end card would be an X1300 or X1600, an AGP 7300GS is another option.</div>
</td>
</tr>
</table>
</div><br />
actually get a 6600 AGP, way better card than any af those mentioned and they are around 70 now.
Hit the phonebook or the yellow pages or a local internet directory. Then call around a bit what local shops have laying around.... A dedicated video card and another stick of RAM would be nice
Discussion Starter #16
ahh man dont forget all this hardware cost money. 512mb ram stick = bout $70 graphics card = over $100. im only 16
I have the same core in mine just clocked 1100mhz faster.<br />
<br />
I'm not sure what settings that SiS chipset has in the bios for overclocking, so if you could post all the settings you have to OC then I can help you give it a nice performance boost. If your chipset has a locked AGP PCI bus then you could prolly hit 2.4ghz.<br />
<br />
If you go on eBay you will find a seller known as the fast memory man, he sells 1gb pc3200 for around 38$<br />
<br />
EDIT: I just thought about it, shipping would be outragous
Discussion Starter #19
o all the setting soz just read it all np will in a sec <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
1 - 20 of 28 Posts
