1 - 3 of 3 Posts
Made a new pc with the a10 7850k and Extreme6+ laos has an 550 W PSU 16gb ram with 120gb ssd and blu ray writer.
Now for monitor i have three monitor.
1 Dell 2713h
2. Achieva Korean monitor (2560 X1440)
3. Crossover Korean monitor 2560 X1440
the mobo has DP,hdmi and DVI -dual port.
If i connect Only dell either with HDMI or DP it works perfect in the system.
If i connect one Achieva monitor only to MB to dvi dual i only get 1920 X1080p output only.
If i boot up with Achieve monitor and then connect Dell it works as well.
Things i cant do is connect both monitor and boot then it just hangs on welcome windows screen.
also i ahve a 5770 XFX card lying around which i can use for all three monitors.I tried putting that in the mother board and now my PC wont even boot to even first screen...
any idea or suggestions on this??
V
5770 earlier was working perfect with my dell 2713 and achieva and crossover....its just adding the card to the Mobo it doesnt boot up or support two monitor...tal;ked to Asrock people and they said u need to take it back to the manufacturer
1 - 3 of 3 Posts
