Amd Athlon 64 X2 3800+ OVerclock?
529 Views 1 Reply 2 Participants Last post by  logan
Hello, well here is my question.. i have a gateway gt5028 with unlocked bios im trying to overclock my cpu but when i turn up the freq and boot windows there is no difference and i also check cpu z told me stock info any ideas?
Thanks in Advance
My specs
Amd Athlon 64 X2 3800+ 2.0ghz... for now i hope
3gb Ram
Nvidia 8600gt XXX Edition 620core 800mem
500watt Ocz Stealthxtreme PSU
1 - 2 of 2 Posts
First off, welcome to the forum, this place is great.
Just a few questions, because this would be the first "unlocked" bios that I've seen if its true. Is the bios unlocked in the sense that you can boot into and change things like the boot order, or in the sense that you can adjust things like these: reference clock (fsb), vcore, vdimm, ram timings, PCI-e frequency, etc?
Forgive me if I'm a little skeptical, because I've never seen an unlocked OEM board before. But make sure that you've saved your changes before you exit BIOS, and that you're not trying anything crazy (in some boards, if you change to much, to fast, it will just re-set back to stock settings).
Let us know how it goes.
Good luck
1 - 2 of 2 Posts
