Pointless over clock on a jank set up I know but I thought I would give it a try, have seen online some where that the 78LMT are a horrible standard mother boards with very little overclocking room, dont know how to set my voltages or ram timings but it seems stable on auto about 1 hour 20 mins of prime95 blend test with decent temps, if someone could look over my screen shots and tell me what my ram timings should be on manual and if I have everything else set correct would be awesome thanks.
NB heat sink feels rather hot even tho temps dont look too bad?
Last screen shot is temps on idol rest are during prime95 test showing various cpuz tabs
CPU - AMD Athlon II x2 270 @ 3740 GHZ
MB - LMT78-USB3 REV 6.0
RAM - 8 gig (2x4) Crucial Technology DDR3L 1600 MHz / PC3L-12800
Cooling - Standard AMD fan and heat sink and 2 large case fans
GPU - Geforce 9400gt with no fan has an older smaller case fan cable tied under it lols
PSU - fairly new about 5 months old either 750/650 watt
