1 - 14 of 14 Posts
Okay, this thing is running at 51C (123F) according to CPUID Hardware monitor.
The performance is being CRAPPY right now... things seem to EASILY consume the whole processor right now. Never seemed to before.
So a friend on MSN asked about how hot it's getting when I told him. I know how hot now, but I just don't have a clue if this temp is good or bad on this processor. I only know of newer ones these days.
55-65*C is the safe range of those chips (if you aren't overclocking). Lower the better, but if you're loading at around 50*C you should be fine.
Only loads that shoot up are going from one page to the other in FireFox right now, but nothing constant.
I just find it odd because my Intel Atom netbook doesn't have this kind of problem with loads on programs like firefox or AVG.
It drives up to the point in making music studder on here, if that tells anyone anything. I run 1GB RAM, Windows XP SP2, and have a ATI AIW 9600 as a GPU right now.
it's an issue with the athlon socket a's. I'm running a athlon 1500+ socket a right now, and my temps are 47C just doing web browsing. You are in a safe range. I had to buy a new heatsink and fan last year due to this thing reaching 90c and shutting down. put the new HSF in and a new case fan, and it hasn't gone above 55c. If anything, remove the hsf and clean the old thermal paste off and put some AS5 on there. I did, and am satisfied. the old thermal past was harder than a rock and clumped.
Discussion Starter · #8 ·
Well, even when AVG resident shield skyrocketed the usage... but I went ahead and rebooted the whole machine. (I had it off over night.)
Using FireFox 3.0.15.
It still drives up the CPU usage, but the music isn't studdering now from it. Though is it natural for FF to drive it up? I know AVG's reason, because everytime I open a file it scans it.
Originally Posted by youra6
even when overclocking, the temps should never go above 62
For those old chips it's fine. They are rated at 85*C if I remember correctly, but you wouldn't want it to hit 70*C anyway.
How old is the computer? What OS is it running? Did this behavior start recently or is it an old issue that has gotten worse?
My old phenom 9950 used to shoot sometimes maybe to 45-47 when opening FF or Everest utility but then immediately drop down to 37-38. Its not a socket issue. The CPU is just under load when using applications like firefox.
If using FF causes issues, I read one guy got rid of it by disabling java and restarting FF
you should tell your friend to try that.
yeah, my FF does it as well, takes a good 20-30 seconds to fully open. im kinda used to it, or I just use my laptop which has a C2D and I dont have the issue.
My mistake. Older Athlon chips do have a higher thermal limit
Discussion Starter · #13 ·
Oh I'm sorry, I must have written the original post a little confusing. I mean that my friend on MSN asked me how hot my CPU was getting when I told him of my problem.
Honestly, I never watched the CPU usage until recently. Though Java does kind of use some too when used, but nothing to the point of freezing, just a few seconds of wait sometimes.
Ooh, okay, but I may want to upgrade the CPU cooling anyways. I never overclocked it either, I don't even know how. lol
It's not that bad on here, but it seems to not cause any studdering any music now since I rebooted it. Guess an issue with something else there?
Some reason I had in mind the older chips didn't handle as much. Guess I was wrong.
They were built on a bigger process (130nm), which meant higher voltage and temperature tolerances. I still got my old Thoroughbred at 1.85V
1 - 14 of 14 Posts
