AMD/ATI Old Gaming Rig
548 Views 4 Replies 5 Participants Last post by  Carlitos714
Hey guys, I need an appraisal for this older watercooled gaming rig.
Specs:
Water cooled CPU and GPUs.
CPU: AMD X2 64 6000+ 3.1Ghz (With D-Tek Fusion V2 Water block)
MEM: 2GB Team Xtreme PC2-6400 (800Mhz)
Motherboard: ASUS M2R32-MVP Crossfire
GPUs: 2 - ATI 2900Xts In Crossfire(Each with a Koolance full coverage water block.)
Harddrive: Western Digital 7200RPM 500GB.
PSU: 850Watt Silverstone.
Case: Thermaltake Armor Jr.
2 X 120MM rads (One Premochill one majicool)
Swiftech high end pump.
UV reactive water.
16xDVD-Burner.
Onboard 5.1 Sound
Blue LEDs.
120mm fans.
Antec spot fan directed at the Southbridge.
Windows Vista ultimate 64bit.
4XUSB V2.0 ports
10/100/1000 Ethernet port.
Cheers!
1 - 5 of 5 Posts
You could probably get more if you part it out, the CPU and board are rather outdated. Perhaps you could sell the PSU and case as a combo deal, and the watercooling kit and videocards seperate as well.
That. If you sold it all together, though, you could probably get about $475.
You could get some some good bucks for some of those parts, if you part it out.
$500 shipped. i would part it out. youd make more $$$$
1 - 5 of 5 Posts
