1 - 20 of 21 Posts
Ok so i read on another site that if you remove all the pins from a AMD CPU it will fit and work on the intel motherboard better then a intel processor.
So i bought this CPU (Paid $90) a AMD Phenom II x4
Which LGA slot should i put the CPU in?
Take a Look! I removed all the pins!
Thanks in advance!
I was expecting a thread about an ancient cpu- 386 or 486 maybe. Back when they were same socket compatable. This thread is just silly.
224
Originally Posted by jrbroad77 View Post
Not sure if troll or just troll...
^ this
put it on top of an lga cpu (glue), then in a lga slot.
I hope that CPU was already dead. I hate to see good hardware wasted.
No no no.
It'll work.
Just gotta keychain the mobo too, problem solved.
Add some laptop ram while you're at it so it's extra portable for your keys.
1 - 20 of 21 Posts
