Originally Posted by
benko
Everything was good until Phenom II. I completely know their products. But now, there is just too many of them, and I admit, I wasn't realy following all. I know Intel line completely, every single cpu/architecture, even mobile version(!) and I think that they nameing nomenclature is waaay better tham AMD's. So if somebody can make a little overwiev of those AMD lineup, Trinty, Llano, Bulldozer, Zambezi.... which is newer, which is faster, which saves more energy, with what Intel chip they compare ? etc, etc...
Hope somebody can help, because I am sure I'm not the only one.
P.S. searched a little bit Internet, cannot find any summary of that.
Ok So after Phenom II AMD split up into two lines, they had APU's and CPU's
Lets start with the CPU's
Bulldozer (codename Zambezi) are quad, hex, and oct-core processors based on a 32nm fab process, some may argue that they are actually a dual tri and quad core, but lets leave it the first way for now. Bulldozer was a flop due to low IPC and high heat and power.
Piledriver (Codename Vishera) are the follow up to Bulldozer with higher IPC and Resonant mesh technology which is rumored to reduce power consumption and heat. Piledriver will be produced on a refined 32nm fab and will also come in quad, hex and Oct core.
Both Bulldozer and Plidriver will be socket AM3+ and utilize the 990fx chipset.
Steamroller and the one after that (can't remember the name) will be FM2 and i am unsure of the chipset.
Now APU's
Llano was the first generation of a technology know as an APU. APU is an all in one chip that combines a processor with a discrete level graphics core. Llano utilized older STARS cores from Phenom II and 6000 series graphics. You were able to hybrid crossfire an APU with a compatible GPU. APU Preformance is highly dependant on Ram Speed
Llano was socket FM1
Trinity is the next generation of APU's utilizing new Piledriver cores and 7000 level graphics. They share many qualities only Llano but with a higher IPC and higher level graphics core
Trinity will be socket FM2
Now as far as preformance goes.
Bulldozer uses more power and heat than phenom II and with lower IPC, also, it severely bottlenecks most high end graphics cards
Piledriver seems to have about a 15% increase in IPC putting them a little bit behind sandy bridge and using less power
Llano is perfect for budget gaming rigs, but i've heard the stars cores are really showing their age. also, you cannot use higher level graphics cards without disabling the onboard GPU kind of defeating the purpose.
Trinity based on laptop samples, has a little less power processing wise than a comparable Intel processor, however makes it up with extremely stron graphics performance making it perfect for a low end gaming machine where CPU power won't be a bottlencek
