1 - 20 of 393 Posts
Font Magenta Electric blue Advertising Event
Soon to be released EXPO AMD optimised DDR5 memory.
Likely as with Intel memory, A-die will be preferred. M-die being a close second.
It has been said that like 3800-4000 1-1 the sweet spot for AMD 5000 series CPUs, 6000 1-1 should be the sweet spot for AMD 7000 series CPUs.
  • Helpful
Reactions: Veii and Nelfhunt
PC Evangelist
Hynix M-Die should be good enough if we run it at 6000MHz. Cant wait to get overclocking.
PC Evangelist
It's good to see 4xdimm works with 6000Mts for Hardware Unboxed. Not a catastrophe with running such compared to the official support numbers.
Reactions: LazyGamer
Because I was inverted...
A-die might get better timings though.
thus far, my M-die runs much tighter timings and will run 1T, where my a-die runs higher clocks at lower voltage, but will not run 1T.
M-die would run 7000C30 1T at 1.55v, a-die 7000C32 2T @ 1.4v and 7800C34 2T at 1.48v; at least on Alder lake.
My m-die is ready :)
Some more pictures can be found here:
I'm just waiting for some heatpads so i can install the bitspower heatsinks on my newly arrived a-die :)
Looking forward to test what works best on a 7950x, and if u can run all sticks at the same time..
There should be 0 issues doing up to 6400 with 4-DIMMs on the Asus 4-DIMM daisy chain. It's just much harder to stabilize. I think AMD IMCs might fair better compared to the ADL IMC. No evidence to substantiate this, but I just have a feeling.
I couldn't get two DIMMs to 6400 stable on my Z690 ACE - using nice Dominators and a 12700K.
I'll bet that AMD has significantly better tuning, and that the motherboard manufacturers have learned a thing or two from producing boards for Alder Lake.
[which is why I'm here, to see how y'all do!]
Overclock the World
Oh that channel is fresh
Let me get this up (repost) for everybody
Font Gadget Technology Electric blue Art
BMEBD = M-Die
BAGBD = A-Die
Rectangle Font Circle Parallel Number
Good Luck on SP rating, everyone 🙏🎇
I really don't know what was up with MSI's bogus 6666+ claims, but you could definitely do 6600 on the Strix Z690-F and Hero reliably. You could also do 6400 across 4-DIMMs with enough effort, but certainly 6200 across 4. If you had a 2022 Asus 4-DIMM'er you could probably do 6400 easy, but no one tested it I don't think.
anyone know what this kit uses for IC's? F5-6000J3636F16GX2-TZ5N
Should be Samsung. Broad stroke but I genuinely don't think EXPO kits have anything special about them.
1 - 20 of 393 Posts
