1 - 7 of 7 Posts
I've just recently started to experience random display driver crashes and recoveries. Today the AMD display driver has crashed and recovered 4 times, 3 of which have been in the last 2 hours.
Here's my systems specs:
Windows 7 Home Premium 64-bit
AMD Phenom II X4 965 Black Edition 3.4GHz Quad-Core Processor
MSI 970A-G46 AM3/AM3+ Motherboard
ASUS AMD Radeon HD 6770 1GB GDDR5 Graphics Card
4GB (2 x 2GB) G.SKILL Ripjaws X-Series DDR3 1333MHz RAM Kit
1TB Seagate Barracuda 7200RPM SATA Internal Hard Drive
1TB Seagate GoFlex USB External Hard Drive
Corsair TX-950 950W 80 PLUS Bronze Power Supply
CPU's temperatures for all 4 coures are fine, 30 degrees celsius at idle, no more than 50 degrees celsius when gaming
GPU's temperatures are also fine, 36 degrees celsius at idle, 50-57 degrees celsius when gaming
CPU's active voltage fluctuates between 1.1 volts and 1.5 volts, which is a safe operating voltage range for my particular CPU from what I've researched.
What are the most common reasons for AMD display drivers crashing and recovering?
· Watercooler
When does it crash? Are you using Afterburners on-screen display?
· Watercooler
Well if it is crashing when you are playing a game or trying to load a game and you are using MSI afterburners On-Screen Display function then it is that. I was so frustrated and couldnt figure out why it was happening and it turns out it was the OSD messing everything up. When does it crash and recover?
Based on my Google searches, here is what I got:
Have you tried turning Aero off?
Do you have the latest amd drivers installed?
You could uninstall msi after burner and download sapphire trixx and see if that is working without causing the crashing. If the amd drivers stop crashing, then msi afterburner is the problem. Here is the sapphire trixx website: (https://www.sapphireselectclub.com/ssc/TriXX/)
If that does not work, check this thread out: http://www.tomshardware.com/forum/338953-33-display-driver-stopped-responding-recovered#t2621402 Look at what mattroxlol wrote in the quoted text.
If all else fails, then check out this: http://support.amd.com/us/kbarticles/Pages/737-27116RadeonSeries-ATIKMDAGhasstoppedrespondingerrormessages.aspx
Discussion Starter · #6 ·
I think that based on other answers I've gotten that are related to this problem, I may just do a clean install of the drivers and software.
I first installed legacy drivers and software for an old AMD card, and then when I got my HD 6770, I never bothered to remove/uninstall those legacy drivers and software. I just simply installed more current drivers and software.
The old drivers will most likely be the problem.
1 - 7 of 7 Posts
