AMD FUSION. great for xp amazing for vista
2429 Views 30 Replies 19 Participants Last post by  el gappo
http://game.amd.com/us-en/drivers_fusion.aspx?p=1 i would like to bring attention to this as i for one and im not alone hate all the background programs on vista trying to help you out, keeping things secret asking permision even tho you clicked it. well this handy tool disables all unessercary apps and engages amd boost technology! (oooooooh) well i love it and dont know of anyone else using it so i thought id bring it to your attention aparently it works better with all amd systems but its an improvement with my amd/nvidea. just wack it on expert and enjoi
ive seen 2000 extra 3d marks on a good amd vista machine now thats a boost
Reactions: 5
1 - 20 of 31 Posts
oh and its free
We all know the software very well, and many a test has been run on these forums to conclude just how much this does. But your fervor and eagerness to help others is greatly appriciated.
tried it and it works well, i definately recommend it esp when you got a lot of things running in your pc
Originally Posted by KinZee
Pretty handy, but most of it can be done in a better way.
yeah. Im interested to see if it makes any difference. I do a decent job of determining what is worthless crap running in the background and shutting that stuff down
AND if u are stuck with an intel cpu http://www.tomshardware.com/news/AMD...ntel,6883.html here you go
will using this program shut down programs such as riva tuner which i use to automatically control my gpu fan speed based on temp.
will it cause it to run the fan at stock speed because the program is not on?
if it doesn't then i will be more them willing to give it a try.
no. catalyst and the nvidia softwares are not put to halt.
just try it. i even tried using it with my old sempron with fx5200. it works sweet
I do believe withing the progrsmme you can customize it out.. I notice s difference in performsnce while using it. But one this I did notice is that it shuts down my key binings I have on my keyboard for gamming.. But like I said I am sure I saw where you can edit the settings.
Didn't know about this!
Sig rig benchmarks:
With AMD Fusion on:
10840 3DMarks
Far Cry 2 Ultra High no AA
* Average Framerate: 29.50
* Max. Framerate: 38.27
* Min. Framerate: 24.69
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 34.955
With AMD Fusion off:
10016 3DMarks
* Average Framerate: 26.50
* Max. Framerate: 34.98
* Min. Framerate: 20.76
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 27.815
cool +rep
edit: also, phenom 9600 TLB disabled
amazing
Its really good with two problems:
1: tends to turn the taskbar off requiring a reboot in XP on Expert setting
2: Doesnt work on windows 7
weird. my taskbar stays working.
I never knew about this. Looks fantastic though and I will definitely be giving this a shot when I get home tonight.
SO SO glad I joined OCN!
+rep for the OP
i could never get this software to work for me for some reason kept popping up with some error code (forget what that is now though as not tryed it in months)
glad to see some people are making use of it, i run it on my vista system just to free up memory and stop notifications, allthough it can cause some problems with my steam account logging me out and stuff its worth it just because the os doesnt hassle you all the time
cheers for the rep aswell
Sig rig benchmarks:
With AMD Fusion on:
10840 3DMarks
10016 3DMarks
cool +rep
amazing
if some more people could post like this that would be great, im curious to se the impact on vista, and maybe a run on win7 if its compatible, that could be interesting. nice one skarm
With AMD Fusion on, I got 13212 3dMarks. With it off I got....13212 3dMarks. I've already disabled the services I don't need so I guess I did a good job.
Please note that if you disable the Fusion gaming setting, it'll start a bunch of services you might have already disabled.
1 - 20 of 31 Posts
