I just got everything installed to my pc. Upgrade went off without a hitch...well except with the new Dark Knight cooler I can't plug in my cpufan into the right slot, So I had to use a system fan. Will that be bad in the long run? If I don't OC is it fine? It idles at around 20C right now...
Yet when I did CPUz....Stock it should be 3.3 right? Why when I did CPUz does it say Freq : 3603.13 MHz (200 * 18) I havent done anything to it. Other then install it.
