1 - 20 of 40 Posts
Hello guys. My very first post here.
I have that cpu + mb combo and im trying to OC it. I have everything on my bios set as other people have set theirs and im getting really bad temps. I only have it set at 4.3mhz and my core goes up to 57+ ( i stop prime95 when it hits that high. )
I have a swiftech220x cooler. I even put a fan blowing towards the vrm heatsink. Pls help!!
Thanks
I have everything on my bios set as other people have set theirs.
That is a guaranteed recipe for failure. Oh, welcome!
pass the lortabs
Thats exactly where I went. And y is it a recipe for failure. Pls explain
Well it obviously didn't work out for you. Every board, and especially every cpu is different. Not to mention all the variables like ram, cpu cooling, case cooling, ambient temps etc.... An overclock can't be done by copy and paste. Even if someone had the EXACT same rig there is a really, really, really good chance the bios settings would not work for you. It is not nearly that easy. The advice that was given to read the guide is how everyone here learned. Take your time and do it right and it will be rewarding and fun.
...when you walked in
What is default? "Auto" is the default setting and that could be anything. So why don't you look at CPU-Z and tell us what your voltage is under load. The only reasons you're having high temps are going to be..
A) high voltage
B) bad mount on CPU cooler
C) pump not working
Most likely A.. since you seem to not know what your voltage is. Default is not an answer..
It'd help if you show us screenshots of HWiNFO64 while you run a stress test. Particularly what it says about vcore and temps.
Also be aware that the settings under Digi+ Power Control (notably Load Line Calibration) WILL affect your vcore under load. In how far, you will find out by looking at vcore while running a stress test.
Discussion Starter · #13 ·
about 2 min into Prime95, my socket temp goes up to about 65,66,67 (core @ 52).. so i have to shut it down coz from what I understand, max core temp for this CPU is 70celcius..
Im am sure my cpu block is sitting on my cpu properly with thermalpaste... and i think my pump is working.. otherwise my temp would be a LOT higher...
Suggestions , anyone?!
Discussion Starter · #15 ·
Ambient i say about 23celcius..
Vcore jumps between 1.3-1.34
I used the line method to apply the thermal paste that came with the h220x
System idles at about 18celcius.. but it gets really hot when running prime95.
i lowered the speed to 4.3mhz but im still getting about 54degrees on core and about 68degrees on the socket.. Which is I think i a bit too high with my cooler right??
I also tried to decrease the Vcore to about 1.28v.. but temps were still going up and up.
What else could be causing this....
pass the lortabs
There's definitely something wrong. Try reseating your cooler block.
Discussion Starter · #18 ·
Ok thanks for the tips.. ill try reseating it.... and would you suggest maybe getting Arctic Silver 5 while im at it?! .. and is the extra VRM fan i have even necessary?!
pass the lortabs
AS5 is not the be-all/end-all of paste. What are you using now?
The fan over the VRMs will help once you get your current issues in hand and move on to stabilizing your overclock, as will putting one on the back of the motherboard to cool the socket.
1 - 20 of 40 Posts
