Tip #1. CPU Power Saving Throttling (Bios related)
Disable
*Ensure that CPU NB, Memory or HT Link values are running at default stable values.*
*CPU / Chasis Fan Control (set to full speed for best cooling, if too loud play with the manual speeds.)
Tip #2. CPU Load Throttling (Bios problem)
Known Motherboards with this problem
ASRock 880G Pro3 Bios 1.40
Known Fixed Motherboards & Bios Versions
Coming soon.....
Tip#3. CPU Temp Throttling (CPU/Mosfet / Board)
http://www.frostytech.com/top5heatsinks.cfm
http://www.hardwarecanucks.com/content/reviews/cooling/
http://www.tomshardware.com/charts/cooling-watercooling,44.html
Heatsinks/Cooling Shopping Websites
http://www.quietpc.com/
http://www.frozencpu.com/
http://www.performance-pcs.com
http://www.sidewindercomputers.com/
http://www.xoxide.com/
http://www.svc.com/
http://www.newegg.com/
http://www.tigerdirect.com/
Disable
- AMD Turbo Core Technology
- APM (Application Power Management) *disabling the AMD Turbo Core Technology via AMD OverDrive utility will also disable APM)*
- Cool 'n' Quiet *I actually keep this enabled so I don't waste power since high clocks aren't needed under low loads*
- CPU Thermal Throttle *be careful keep an eye on your temps, especially core temps, leave this enabled if your not the cautious type* (FX-8120 < 61C, FX-8150 <61C, FX-6100 <70C, FX 4100 <71C)
- Core C6 State
- C1E
- Enhanced Halt State
- Any other Power Saving Features in your bios, usually under CPU Advanced, Google them first.
- Load Line Calibration, play with this setting until you get stable voltages under load, remeber every bios is different, some might even be better with it disabled, but most best enabled and manually set.
- Get AMD Overdrive and Open and Enable Turbo Core Control then Push OK then Open and Disable Turbo Core Control then push OK then exit AMD Overdrive.
Coming soon.....
- Get High End Heatsinks/Cooling for your CPU and your Mosfets.
http://www.svc.com/
