AMD/INTEL and NVIDIA/ATI Badges
189 Views 5 Replies 4 Participants Last post by  StarryNite
I've been wanting to remove mine since the first day, I didn't realize that once you chose them you could only change them.
I believe it adds to the fanboism.
Or maybe just add a badge for both?
1 - 6 of 6 Posts
Are you talking about the badges right under your avatar? If so, those are set to what you have selected under your default system.
yes but once you pick them you can only change them, not remove them. I own all type of company's products and have no bias any way (Cept for bang for the buck) and the badges make it look like I do.
Badges don't make fanboys, but fanboy posts make fanboys.
I never look at those badges, normally I look at the user title.
Didn't say it makes them, said it adds to it. I see alot of posts like this, "I see you say that because your a [insert company here] fanboy."
This is true.
Folks have more than one computer these days, and more and more buy now due to speed and features, so a default setting can make folks believe that's the only brand they use (which is often the case with processors, there's some hardcore AMD and Intel types).
I can only use Intel procs, but that doesn't mean I'll always be as loyal as my family, as Intel doesn't pay me for a living and I have to buy my own hardware!
1 - 6 of 6 Posts
