1 - 2 of 2 Posts
Ok, so from what I've read, Intel owns the 1066 MHz & 1333 MHz platform Boards, and AMD has to buy those platforms from Intel, essentially.
My questions I suppose is about AMD's Motherboard limitations, considering I was reading about the Asus M4A78T-E which RAM is DDR3 1066 (max), therefore, is there really a limitation as to how high the processor can reach based upon the MAX ram a motherboard can handle?
And if so, wouldn't that put AMD far behind Intel which has the 1333 Platform, which uses Core i series chips which do not use a front side bus?
I'm just asking for clarification, not wanting to start any wars / trolls here..
Car cheaper than computer
The board can only support 1066 since the cpu can't officially go higher, it is that low so that the early chips could run in spec.
1 - 2 of 2 Posts
