1 - 18 of 18 Posts
( I thought I made this post before, but apparently I didn't
I am looking for a AMD/Nvidia board, that supports the following:
-SLI
-SATA 3
-AMD CPU
I want one that comes highly recommended, and before you say something.
I DO NOT CARE ABOUT THE HACK, I DO NOT CARE ABOUT THE HACK.
There hopefully that got through
Apparently there is no support for GTX 460's, and since that is true, I DO NOT CARE ABOUT THE HACK.
Thank you.
All of this I want to be under or around $100.
Super Moderator
-SLI
-SATA 3
-AMD CPU
Thank you.
Not gonna happen, sorry. The only boards that I know of that have SATA3 and USB 3.0 are the 8xx series from AMD, which support Crossfire only.
You can get a 980a chipset from Nvidia (AMD board). The MSI 980a is a great board. But its not under $100, and it doesn't have the features you're asking for (SATA 3 / USB 3.0).
EDIT:
MSI 980a motherboard - $159.99 shipped
OB MSI 980a motherboard - $119.99 + Shipping
Asus 980a motherboard - $139.99 + Shipping
Those are the ONLY Nvidia boards (of any decent quality) that are even available for AMD right now.
And i doubt that there is a board with at least 2 pcie 16x and good overclocker for only $100, you will need to go a little higher to the $130-$150 range to find a good board with those specs.
Super Moderator
Wow, this seriously sucks.
Is there a good board without SATA 3? Around $100?
Honestly, I'd grab that Open Box MSI 980a board off newegg (if you're in the US that is). That's going to be the best SLI board out (at least right now).
Discussion Starter #7
Wow... Just great.
So I am being anal raped into buying a expensive mobo...
Any suggestions for a mobo that supports SLI and AMD CPU
SCREW THE SATA3.
argggggggghhhhhhhhhhhhhhhhhhhhhhhh hulk is angry!!!!!!!!!!!!!!
That one. It's the best Sli/AMD board IMO
Super Moderator
I just told you, grab the Open Box MSI 980a for $119.99 + Shipping. That's going to be the best SLI board period currently for AMD.
Discussion Starter #10
aarghhhhhhhhhhhhhhhh!
DAMN U CALIFORNIA!!!!!!!!!!!!!!!!!!!!
On newegg I get charged tax, which would bring it up to $123 (around).
but on tigerdirect I can get a new one, which is not bricked (open box is most likely is bricked)
for $160 with a $20 rebate.
DAMN DECISIONS!!
(There is alot of problems with that board apparently......)
Super Moderator
DAMN DECISIONS!!
I have NEVER had an issue buying Open Box off newegg. They also allow a return within 15 days. So as long as it works out of the box, you should be fine to go
. If it doesn't, return it.
And I have read nothing but GOOD things about that board. If you are looking for an SLI AMD board, that is seriously about the ONLY option you have that's any decent.
DAMN DECISIONS!!
The only problem that i found before buying it was the chipset running hot and a TIM change works very good for that.
I have a POS foxconn destroyer with full speed 15x dual gfx card sli and has sata 2. would have been an okay board if they would make bios for the 6 core and if it had crossfire. I think you can still find some on ebay.
Discussion Starter #14
The customer reviews seem to have some bad things to say....
Guess it's my only choice.
EDIT: What's wrong with the RAM, I have to OC to use ram?????
lol?
Super Moderator
lol?
That is with ANY current AMD motherboard. DDR3-1333 is default to the AMD memory controller. You usually need to overclock your reference clock to reach DDR3-1600 (usually, but not always). The DDR3-1600 setting is "technically" an overclock setting.
BUMP.
Before you quote the tos, note that you are wrong.
Actually, according to the ToS, you're not supposed to bump a thread until after 24 hours of inactivity
. But I guess I'm wrong
not sure if the memory type is an issue, but my board was a very satisfying purchase. M4N82 Deluxe. only thing is the ddr2 memory, but a very strong overclocker!!! got my x4 b55 unlocked chip to 4.25, in dual core mode almost 5ghz. 980a chipset, and has the sli(tripple)/AMD combo your looking for. take a gander and see if would work for you.
BUMP.
Badge number officer? Are you highway patrol or what?
1 - 18 of 18 Posts
